67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Wall Layer Grips Missing
Wed, Dec 2, 2015 at 4:32:12 PM | Wall Layer Grips Missing
kittyj2345
Hello,
I have an exterior wall that I would like to edit so that the framing goes up to the bottom of the ceiling joists, but the exterior brick ends at the bottom of the soffit. See "wall section."
You can see in "unlocked" that I have unlocked the top of the brick layer, but the blue grips that should appear for moving the top of the wall layers don't appear- I still only have one Sad
This wall was once attached to the roof, but I detached it. Do I have to delete it and re-draw it in order to modify the layers?
Wed, Dec 2, 2015 at 4:37:06 PM | Wall Layer Grips Missing
kittyj2345
I made a new wall with the same wall type, and I'm still not getting the grips, so it seems that the issue is not that the wall was once attached to the roof.
Wed, Dec 2, 2015 at 4:42:56 PM | Wall Layer Grips Missing
DavidBruinsma
Kitty
I believe you are on the right track - perhaps the stud frame is also unlocked?
Wed, Dec 2, 2015 at 4:56:18 PM | Wall Layer Grips Missing
kittyj2345
That's true, the stud layer was also unlocked! It didn't let me simply lock the stud layer, though. I ended up locking the brick layer and unlocking everything else, which was counterintuitive, but it worked.
Wed, Dec 2, 2015 at 6:48:20 PM | Wall Layer Grips Missing
DavidBruinsma
Kitty
What Version of Revit?
Wed, Dec 2, 2015 at 7:47:51 PM | Wall Layer Grips Missing
kittyj2345
Sorry, I should have said that in my original post. I'm using Revit LT 2014.
Wed, Dec 2, 2015 at 8:37:53 PM | Wall Layer Grips Missing
DavidBruinsma
if you copy that wall into a blank project file (fully purge everything else out) and upload the file here - I will have a quick look at it tonight.
I only have revit 2015 on my work PC, but still have Revit 2014 on my home PC
If i can resolve the problem for you I will then repost the file back to you.
cheers
Exporting and layer modifiers
Wed, Nov 16, 2011 at 4:04:34 PM
Sketch Detail on wall layer
Tue, Mar 31, 2009 at 3:52:18 PM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:01 AM
How to control a single-layer wall?
Wed, Apr 28, 2010 at 2:39:51 AM
EXPOR LAYERS for WALL HATCHES are missing
Wed, Mar 1, 2006 at 8:30:59 AM
Page generation time: 0.9055
