68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Applying a wainscot onto a wall
Mon, Apr 3, 2006 at 11:27:33 AM | Applying a wainscot onto a wall
Bratman
What is the best way to apply a wainscot to the surface of wall. Should I use the host sweep command or build it into the wall type using a profile to sweep the wall? Which one and why? Thank you Justin
Mon, Apr 3, 2006 at 12:08:29 PM | RE: Applying a wainscot onto a wall
coreed
coreed Avatar
4 Stars: 16 Votes
if you build it into the wall type you can fix the height from the top or bottom of the wall and if the wall should change the wainscot will adjust. i don't know if this is possible with a host sweep, but if it is, you would have to set this fix height on each project as oppose to already having it defined in the wall style. best regards, coreed,aia Post edited on 2006-04-03 12:11:31 Post edited on 2006-04-03 12:11:48
Tue, Apr 4, 2006 at 2:10:50 PM | RE: Applying a wainscot onto a wall
quiller
quiller Avatar
2.5 Stars: 3 Votes
Up untill now I've always created this type of detail as a sweep. The only issue is that your design should be at a point where the walls are not going to move. Not that you can't fix your sweep if the wall moves, but if you're putting in this much detail one would expect that the walls are set. I never tried to add a profile to a wall, but its a good option, and it the wall moves your detail is sure to move with it.
Fri, Jun 30, 2006 at 1:38:20 AM | RE: Applying a wainscot onto a wall
drock1627
definately do the sweep in the wall design, cuts itself for doors & windows. I loaded the "brick soldier course", edited the family for a 3' height and put it in wall design
Thu, Jul 6, 2006 at 11:41:46 PM | RE: Applying a wainscot onto a wall
browncat
I agree with coreed. A wall type is the best solution. Unless of course that you do not intend to adjust your height. But for me to adjust the height or not I will still use the wall type! You'll never know when your client or your boss suddenly decide on adjusting it. Kinda long to do but it's worth it.
Thu, Jan 15, 2015 at 10:03:17 AM | Applying a wainscot onto a wall
Kpinakidis
I have created the wainscotting by using the sweep and editting the type to 3" like drock1627 had explained.
Now I am having trouble getting the sweeps to snap together in the corners making the 45 degree corner. Does anyone know a tool i can use to make the horizontal and verticle wall sweeps snap together in the 4 corners to make essentially a rectangle or square?
Kristina
Thu, Jan 15, 2015 at 10:14:28 AM | Applying a wainscot onto a wall
You say you did like drock1627 described but he only described sweeps in wall definitions - not in-place wall sweeps.  There are no vertical sweep definitions in walls so those must be in-place.   These two will probably never join as you would like.  The wall defined sweep will miter correctly at intersecting wall corners.
An image of what you are trying to do would help.
Wed, Feb 18, 2015 at 3:52:25 PM | Applying a wainscot onto a wall
KCren
Download this family. It's fully parametric and works very well.
http://www.revitcity.com/downloads.php?action=view&object_id=9134
Brick Wainscot Covers Door and Window Trim
Thu, Mar 19, 2009 at 1:24:51 AM
Stone Wainscot
Thu, Mar 27, 2008 at 4:44:41 PM
Interior Walls - Wainscot Panels - Revit 2018.2
Mon, Feb 12, 2018 at 4:55:15 PM
unlock finish materials on both sides of wall
Wed, Mar 30, 2011 at 4:14:43 AM
I cant think of the right word!
Wed, Aug 15, 2007 at 6:34:57 PM
Page generation time: 23.3246
