42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> revit 2015-exterior elevations horizontal lines of wood siding
i created an exterior wall with wood siding.
when i use the visual style "realistic" it looks great.
i see the horizontal lines of the lap siding.
but i'm in the construction document phase, i don't need colors, but i do need to see the horiz lines.
when i switch to visual style "hidden" all the horiz lines of the siding disappear.
the same thing happens with the roof shingles.
can anyone help?
thanks!
robert Byrd
Edit your material and add the correct model hatch in the graphics tab - surface pattern.
You could probably go into the type properties of the wall, click on structure and then add or edit exterior material in order to change the surface pattern to suit your desired effect. Sometimes it's also just a matter of changing the detail level to fine. I hope that's clear, if not, let me know.
rendering horizontal wood siding. |
Wed, Aug 5, 2009 at 10:49:00 AM
Wood Siding |
Fri, Nov 22, 2019 at 3:17:58 PM
11
How do i add wood siding in the exterior wall? Need major help! |
Tue, May 15, 2018 at 9:57:18 AM
Wood siding |
Wed, May 1, 2013 at 12:13:58 PM
Timber cladding (hit or miss style) in revit architecture 2012 |
Tue, Nov 6, 2012 at 9:08:59 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
