27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Hiding line behind object in 3D view
Wed, Nov 25, 2015 at 8:28:17 AM | Hiding line behind object in 3D view
Runewriedt
Hello,
My problem is as follows: I am making a diagram in a 3D axonometric view, and I want to thicken only the OUTLINE of one of the generic model components - for that, I am using the LW Linework Tool and clicking the individual lines. If there's an easier way to do this, stop me right here and tell me, please!
So select my desired line style and click a line - but now it shows in front of the object in front (attached image). How can I avoid this? I am in Hidden Lines view and everything. Can I create a custom line style that hides itself behind objects? I do not want dotted lines, just nothing showing.
Thanks in advance,
Rune
Wed, Nov 25, 2015 at 8:32:19 AM | Hiding line behind object in 3D view
Runewriedt
This screen capture actually shows my problem better:
Wed, Nov 25, 2015 at 9:42:25 AM | Hiding line behind object in 3D view
As you use the line tool you will see a control button on the end so you can control the length of the line.  But you can not drag this later.   If you make a mistake, use the line tool again to place a by category.    You can drag a line back to do one end of an edge, the use the tool again to do the other end.
Wed, Nov 25, 2015 at 11:27:56 AM | Hiding line behind object in 3D view
Runewriedt
That is perfect, and so simple, thank you so much. I wonder why this has to be done in such an awkward manner...
Wed, Nov 25, 2015 at 6:50:34 PM | Hiding line behind object in 3D view
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can also override the object’s projection lines.
Select an object -> right click -> override graphics in view -> by element -> projection lines -> weight.
Unless you want to highlight only some of the edges of the object, then use the linework tool.
Edited on: Wed, Nov 25, 2015 at 6:52:39 PM
keynoting hidden object
Tue, Jul 6, 2010 at 1:48:09 PM
Hidden Object comes back after changing View Template
Wed, Apr 19, 2017 at 12:24:45 PM
Object Style not showing unless object highlighted
Thu, Jun 8, 2017 at 3:29:24 AM
Dimension line fixed distance from an Object
Tue, Aug 22, 2017 at 8:18:26 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Page generation time: 13.3995
