Forums >> Revit Building >> Technical Support >> Scaling Revit family
I would like to scale this family downloaded from Revit City to the size I need (approx 300mm). Apparently it's simple according to the family blurb! How please?
If the family is not parametric then you have to edit the family. Without looking, I expect this to be a CAD (skp) file import in the family. Edit the family and scale the import.
Yep, it is a cad import. From revit, export to cad, scale it and load it back to revit. Or, just use attached file (file over 2mb, so it's zipped and split into two files).
Edited on: Wed, Nov 25, 2015 at 12:46:56 PM
2nd file
EDIT: Sorry, it doesn't work
Edited on: Wed, Nov 25, 2015 at 12:51:08 PM
Scaling Family or component- similar to scaling jpeg |
Mon, May 12, 2014 at 2:44:09 PM
Scaling dwg's in families |
Wed, Dec 16, 2009 at 10:37:41 AM
Scaling a family |
Tue, Jan 13, 2009 at 12:45:20 PM
Family Scaling |
Thu, Oct 6, 2016 at 10:44:39 AM
Annotation scaling within Familes |
Mon, Sep 24, 2012 at 7:17:25 AM
Members: | 2115521 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
