50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Toposurface
Fri, Nov 20, 2015 at 9:04:11 AM | Toposurface
simon1688
At the start of the project I modelled the ground level at 25m I then modelled the substructure and superstruture and then the ground level changed to 25.300m when I create a toposurface its coming in at the oringial ground level of 25m and not the new ground level. How can I get the topsurface to come in at the latest ground level?
Revit 2014 user
Fri, Nov 20, 2015 at 9:20:56 AM | Toposurface
simon1688
I could create a seperate site file and link this back in but is there a way to fix this without creating a seperate site file?
Revit 2014 user
Fri, Nov 20, 2015 at 11:56:27 AM | Toposurface
If possible, it is always best to create a topo from a points file or CAD file with countors at correct elevations.   When you create a topo in Revit by placing points, that topo is just relavant to the working level of the plan it was created from -NOT related to anything else.
Yor fix here is to go to a section where you can move the topo you created.
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 0.4148
