93 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked Revit model not importing in the correct orientation
Thu, Nov 19, 2015 at 10:39:01 AM | Linked Revit model not importing in the correct orientation
ArchimediaIE
Hi -
I have an older revit model of a building which I need to link to a new revit model (model 2) which is the site of the linked revit model (model 1).
When I link model 1 inside to model 2 the orientation of the model 1 is incorrect - even though the True North and location is the same for both. I noticed that I have a Project North set on model 1 - and that is the orientation it is coming in as, even though the true north is the same, which is what I thought would take preference.
Can someone please advise on how to link the model into my new site correctly please?
By the way I have tried rotated Project North on Model 1 to be the same as True North but this messes up some family locations and orientations even further.
Thanks in advance.
PeterC
Fri, Nov 20, 2015 at 12:33:13 AM | Linked Revit model not importing in the correct orientation
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Read up on shared coordinates. When you have more than one model, you load the second model into the first. Ensure the first model is correctly located and orientated. Then you need to place the linked model in the correct position whilst it is loaded into the first model. Then you need to use the shared coordinates tool to tell the second link model to save its position. Have a look at this. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Collaborate/files/GUID-B82147D6-7EAB-48AB-B0C3-3B160E2DCD17-htm.html
Fri, Nov 20, 2015 at 4:00:36 AM | Linked Revit model not importing in the correct orientation
ArchimediaIE
Hi Beaucoupnice,
Thanks for your advice, it's much appreciated, however, I am already using Shared Coords -I use it all the time, in fact the model in question has 2 autocad dwgs linked to it using shared coords and they are fine. It's just that this revit model isnt orientating correctly even though I am importing using shared co-ords. The orientation it is coming in with is the Project North rather than True North - and I have no way to select True North when linking the file.
I will take a look at the link you gave me just in case I am missing anything, however, if you can think of anything else I may be doing wrong, I would really appreciate it?
Regards.
Linked Revit model not visible
Fri, Aug 21, 2009 at 6:23:21 AM
Query regarding Linked Structural revit model
Mon, Apr 8, 2013 at 7:23:45 AM
Door # in linked revit model not updating in main model
Tue, May 5, 2020 at 5:54:11 PM
Project north rotated in a linked revit model
Mon, Apr 8, 2019 at 1:48:16 PM
How to show a correct section of a linked dwg model
Wed, Sep 18, 2013 at 8:08:11 AM
Page generation time: 4.4129
