Forums >> Revit Systems >> Technical Support >> Orange lines in 3D view on self-made revolved family features
Hi
I have made several pipe and mechanical equipment using the revolve function. But when I load them into my model an orange line appeares representing the sketch from which I revolved my feature. I have tried turning off virtually every feature in the visibility/graphics panel, but I cannot hide them... Any tips?
Thanks
Did you do any linewortk in the family? I doubt this is your revolve sketch - instead get rid of your layout lines which must be 3D.
Thank you for your reply WWHub.
I think I made the shape as a line first, outside the revolve feature. Then I selected the lines to use as a basis when revolving. Im used to this from other CAD software. Do you mean that I should not do this in Revit, and only sketch within the 3D tools (extrude, revolve etc.)?
Thanks again!
Yes, why sketch twice?
Ok! but I don't sketch twice, I use model lines to sketch the outline. Then I choose the revolve tool, and just pick those lines. Thought it might delete my revolve if I just deleted the lines afterwards, but nothing bad happened
Picking (pointing) to a line is a sketch ....
A very, very long time ago, we used layout lines to draft almost everything, especially when we inked. Now it is a complete waste of time - just sketch it once. With a similar thought - Don't layout walls using lines - use walls! ...while watching your temporary dimensions.
Ok, now I get it! Thanks for clearing that up, and saving me some time and effort!
Not to intervein, but on the subject, if you do the same thing with reference lines, and snap your dimensions to then, i found you get hte best results regarding parametric families, and contrainsts. That can be one of the most frustrating things, when you think you done with a family file that has like 10 different types, and 1 of them do not work because "Constraints are not satisfied" ... UGH!, like charlie-brown-and-the-punt-fakout UGH! =)
Lines made with linework tool disappear |
Wed, Sep 21, 2011 at 7:46:24 AM
Strange orange lines in linked file |
Tue, Sep 9, 2008 at 11:10:02 AM
colored reference lines...or something |
Wed, Sep 4, 2013 at 3:42:23 PM
Made a new family but ant rotate it properly |
Mon, Jun 13, 2011 at 12:32:46 PM
Void extrusions showing up orange even when rendered |
Fri, Mar 8, 2019 at 1:35:45 PM
Members: | 2100498 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
