72 Users Online (71 Members):
Forums >> Revit Systems >> Technical Support >> Loading Families
I am trying to load a family and when I go to insert>load family>select the one I want it does not show up in my project
I am not getting any type of error message
Family insertion is dependent on several things.
- Being in the correct view
- Having the family category on in VG for that view
- Being in the correct process. You can't place a beam while in the door process.
- Setting the placement face correctly for face based models. (Look at your menu bar for this.)
What kind of family are loading and where are you looking for it in your project?
The best way i found to load a family in, is to go to the "Insert" tab first, then click load family, this doesn't limit you to the type of catagory of the family, so all you are lmited to is whether it is a system family or not, such as a Viewport, or a pipe type. In a system family case, you can "Transfer Project Standards" from any project that is linked into your prject. With this command you can basically "adopt" those kinds of families from the linked file to your file you are working in. If the family doesn't have a lookup table/ type catalogue, then i find myself just dragging & dropping from a windows explorer.
Hope the explanation helps with this question and any other similiar future situations.
Loading Families |
Tue, Apr 21, 2009 at 4:41:24 PM
Loading families |
Thu, Apr 25, 2013 at 11:23:05 AM
Issues with loading downloaded families |
Thu, Jan 9, 2014 at 12:11:36 PM
Revit Architecture 2015 - Families not loading |
Mon, May 25, 2015 at 10:44:08 AM
Fri, Feb 1, 2013 at 11:15:08 AM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
