88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:11:44 PM | Copy Original Type Not Available in Copy Monitor Options Dialogue
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Why would this be? I'm trying to copy a curtain wall from a linked model that has set divisions and segments and for some reason this original type is not available when I copy monitor. The problem is that it was at one point because I was able to copy monitor some of these elements in the model an hour ago.
Fri, Nov 6, 2015 at 2:16:27 PM | Copy Original Type Not Available in Copy Monitor Options Dialogue
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I take that back...revit failed to do this at all....it doesn't look like it can successfully copy curtain walls with custom segments add or subtracted...W.T.F. This is a total fail. Why can't Revit do this?!!! This is bad.
Copy/monitor problems
Wed, Apr 26, 2006 at 11:56:48 AM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Copy Monitor Grids
Tue, Feb 3, 2015 at 8:20:16 AM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Page generation time: 0.7205
