75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Generic Error - Curtain Panel Family - uh...What?
Tue, Oct 27, 2015 at 4:50:59 PM | Generic Error - Curtain Panel Family - uh...What?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I'm working on a curtain panel family where I'm trying to nest two generic model families to document two seperate detail conditions. I want to join the two together but when I do I get a "generic error" message. That's a new one for me! Has anyone seen this before?
Tue, Oct 27, 2015 at 5:28:21 PM | Generic Error - Curtain Panel Family - uh...What?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Looks like it is a problem with trying to nest detail components in with the respective generic models. Revit wont allow them to join if they do. Does anyone know why this limitation exists? It would be nice to nest components in families to capture varying detail conditions.
Tue, Oct 27, 2015 at 7:11:56 PM | Generic Error - Curtain Panel Family - uh...What?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Help me understand a little better--your picture is not too clear.
You have two small separate families nested into your curtain panel, and the error is that you cannot join (anything/the two small parts together?) with join geometry?
I would not be suprised. My first instinct (without really understanding the problem) is that it'd be easier acting subtractively that additively. your second nested family could be a void. voids cut more automatically than geometry joins.
Edited on: Tue, Oct 27, 2015 at 7:12:58 PM
Tue, Oct 27, 2015 at 7:44:30 PM | Generic Error - Curtain Panel Family - uh...What?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
You can definitely join two generic models together. I test and verified as much. In the image, the orange highlighted item is referencing the erro, and the adjacent, mirror image of a similar element was the one to be joined. The theory of this approach was to have the generic models nested into the curtain panel family act as containers for two seperate detail conditions occurring in the same panel - each having detail component families nested into each of them respectively. What I seem to have determined is that Revit will not allow elements that have nested detail components to join together - generating the "Generic Error." Unfortunately, as a result, I have abandoned this approach and will have to place the desired details manually as they occur in the over all curtain wall system, which, is not really that bad since I wouldn't see them in anything other than a fine level detail view. Thanks for your reply and hopefully this little investigation of mine proves useful.
Nesting curtain panel family
Mon, Mar 25, 2013 at 7:56:10 AM
Need Help Aligning /Locking Nested Components to Host Curtain Wall Panel
Fri, Sep 4, 2009 at 9:57:10 AM
Curtain Wall System with Wavy Glass Panel
Sun, Mar 26, 2017 at 1:02:18 PM
Curtain Panel Yes/No Parameter
Wed, Oct 3, 2012 at 5:45:00 PM
Custom panel family within a curtain system
Tue, Nov 3, 2009 at 11:59:10 AM
Page generation time: 1.1804
