39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Block elements.
Tue, Oct 27, 2015 at 6:40:28 AM | Block elements.
lukdab
Hello.
I have old building scanned with laser and then model made in revit. The model is not accurate (not perpendicualr walls, not same windows etc.) and I want it to remain like that. But when I draw a new wall near to existing they join with each other and stretch. When I delete the new one the old don't come back to its original position. How can I block the existing model? I made group of it, I pinned it. Nothing helps. I dont want to link it because during my work I demolish some elements and sometimes I have to "undemolished" them.
What should I do?
Sorry for my english.
Regards.
Tue, Oct 27, 2015 at 7:27:44 AM | Block elements.
The only thing I can suggest is to place your new wall close to the existing, then turn off the wall join and drag the end to the existing wall.
Tue, Oct 27, 2015 at 8:14:02 AM | Block elements.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
…and if you’re working on 2016 R2, you can select disallow join option right on the option bar while in the wall command. Revit will remember the selection next time you place a wall. A great time saver.
Pozdrawiam.
Wed, Oct 28, 2015 at 3:44:27 AM | Block elements.
lukdab
It seems like it's the only solution. I hoped there's other way. It would be very useful option:/
THX.
DziękiWinking
Block existing model. [ 1 2 ]
Tue, May 24, 2016 at 2:11:05 PM
16
Split Face Masonry Block
Thu, Aug 3, 2006 at 6:25:54 PM
Revit 2012 Export To DWG. Titleblock exported as Block.
Wed, Jun 12, 2013 at 6:16:23 PM
How do I Edit the Apperence of a Note Block
Mon, Jan 12, 2009 at 1:44:04 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Page generation time: 1.6128
