84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do you rotate surface pattern on stair treads and landings?
Fri, Oct 23, 2015 at 1:49:51 PM | How do you rotate surface pattern on stair treads and landings?
aoyalers
Fri, Oct 23, 2015 at 2:03:54 PM | How do you rotate surface pattern on stair treads and landings?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
well, if your surface pattern is a model hatch instead of a drafting hatch, you can select a line of the hatch (may requiring hitting tab a few times) and then rotate or align your selected line with some model feature, like a tread nosing.
This is also going to rotate any render material associated with the hatch, FYI.
Edited on: Fri, Oct 23, 2015 at 2:04:25 PM
Fri, Oct 23, 2015 at 4:22:40 PM | How do you rotate surface pattern on stair treads and landings?
aoyalers
That is exactly my problem. It is a model pattern, hit tab, was able to pick the line, but it can not rotate or move.
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
Stairs - steel & precast conc treads
Mon, Dec 20, 2004 at 12:46:06 AM
Stair Surface Pattern Not Displaying
Wed, Sep 8, 2010 at 10:05:09 AM
Rotate surface pattern on a model-in-place blend
Fri, Mar 30, 2012 at 3:47:08 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Page generation time: 0.9646
