76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> In Place Model of floor needs to have same parameters as Structural floor
Fri, Oct 23, 2015 at 12:51:08 PM | In Place Model of floor needs to have same parameters as Structural floor
jsel13
I have a complicated In Place Model of a floor that i want to make a Structural Floor
I need the same parameters to show up that show up in a regular structural floor, but i cant seem to get them. we used filters for a slab edge plan that arent working on the In Place Modeled Floor because i dont have the same parameters
anyone have any clue how to do this?
the parameter im looking for is pretty simple, i need to check off the YES/NO parameter that says its a STRUCTURAL/STRUCTURAL
please help, deadline very soon
thanks!
Fri, Oct 23, 2015 at 1:54:39 PM | In Place Model of floor needs to have same parameters as Structural floor
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can definitely create a new Yes / No, 'Project Parameter' named 'Structural' and apply that to floor types and slab edges and it will work with in-place floors and show up as a parameter on the properties pallete. It won't actually be a true REVIT Structural floor however so not sure whether it gives you the end result you want.
Edited on: Fri, Oct 23, 2015 at 1:55:13 PM
Fri, Oct 23, 2015 at 2:00:45 PM | In Place Model of floor needs to have same parameters as Structural floor
jsel13
Yeah i tried that, but it didnt work. as you said, its not a true Structural Floor Parameter
Fri, Oct 23, 2015 at 2:06:54 PM | In Place Model of floor needs to have same parameters as Structural floor
You will need to add this as a project parameter to floors.   You need that from your shared parameter file.
Fri, Oct 23, 2015 at 2:29:12 PM | In Place Model of floor needs to have same parameters as Structural floor
jsel13
tried that, not an option
theres no option for a yes/no parameter called "Structural"
Fri, Oct 23, 2015 at 3:33:30 PM | In Place Model of floor needs to have same parameters as Structural floor
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
WWHub answered your question.  You need to ADD this as a Project Parameter.  Under the Manage>Project Parameters then ADD a parameter called "Structural" and make the category "floor".  Then when you create an in-place component you can check it to be structural or not.
Out of curiousity what is so complicated about this floor that you cannot create it with a regular floor?
Edited on: Fri, Oct 23, 2015 at 3:34:33 PM
RAC 2010 Structural Floor V Floor - Whats the difference
Tue, Jul 27, 2010 at 8:35:33 AM
Different between Structural Floor and Floor
Fri, Dec 10, 2010 at 4:47:12 AM
how to make beams from a mass model, and how to add a floor to it
Sun, Oct 22, 2017 at 1:10:11 PM
Creating a schedule for floor areas - families and model in-place mass
Mon, Sep 17, 2012 at 3:00:21 PM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Page generation time: 2.4269
