50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Referenced views floating in space
Thu, Oct 22, 2015 at 1:58:00 PM | Referenced views floating in space
revitape
revitape Avatar
4.5 Stars: 9 Votes
R14...
I've never seen anything like this... For sections, callouts, and other detail views certain section marks are showing up floating well outside the annotation crop box. (S2)
When we drag these views on to sheets this becomes an obvious problem as they may interfere with other views, not to mention the referenced view doesn't refer to anything we want in that view anyway. (S3)
The very odd thing is that when you do a "zoom to fit" on the sheet, it doesn't recognize those extraneous referenced views out there. (S1) This is good since it doesn't screw up printing in any way but we still need to resolve this problem.
Is this a graphical glitch or has someone experienced this before?
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Thu, Oct 22, 2015 at 2:26:59 PM | Referenced views floating in space
I have seen this for several years and not sure what causes it.  I always just pick them and hide in view.  Probably should do something else but never have seen an answer to this.
Thu, Oct 22, 2015 at 2:43:48 PM | Referenced views floating in space
revitape
revitape Avatar
4.5 Stars: 9 Votes
Well curse, that's reassuring and disappointing at the same time. Good to know it wasn't something on our end and seems to be a Revit issue.
Floating Staircases
Fri, Oct 31, 2014 at 1:09:22 PM
export dwg with views not referenced
Thu, Apr 29, 2010 at 4:23:32 AM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Importing Paper Space/Model Space from CAD File
Mon, Nov 17, 2014 at 9:46:02 AM
Referenced view
Fri, Jan 13, 2012 at 1:28:09 PM
Page generation time: 0.9842
