126 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> line weights in section
Thu, Mar 30, 2006 at 10:17:37 PM | line weights in section
devil13
does anyone know how to set the line weights in section such that the furthest thing has the lightest line weight than the things infront?
Thu, Mar 30, 2006 at 10:27:10 PM | RE: line weights in section
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
View depth clipping is not yet possible in revit. It is a wishlist item.
Thu, Mar 30, 2006 at 11:04:48 PM | RE:
devil13
oh... hmmm.... thats a pity..
anyway thanks for your reply mr spot! Winking
Fri, Mar 31, 2006 at 1:32:50 AM | RE: line weights in section
eldados
eldados Avatar
4.5 Stars: 8 Votes
like spot said it's a wish from long time ago... and Revit 9 is not going to bring joy either... you can play with override host layer in your graphic/visibility setting and set cut line style to show a heavy line and use the linework tool to set a light gray colour to items far away... a lot of work but that's what we are stuck with right now...
Integrator
KarelCAD
Fri, Mar 31, 2006 at 1:50:57 AM | RE:
devil13
well..... i guess using photoshop would be make better?
at least it cut down all the hastle that have to go through setting in revit
Tue, Sep 25, 2007 at 9:14:55 AM | line weights in section
kkohutek
kkohutek Avatar
4 Stars: 7 Votes
i'm struggling here
but yeah, i think photoshop is a good option
just select the area you want and change the curves.
altho, it will become a raster image, and ploting with it isn't the best way.
Tue, Sep 25, 2007 at 2:46:14 PM | line weights in section
3.5 Stars: 395 Votes
kkohutek,
Watch yourself with these older posts, things have changed with REVIT Architecture.  Now you can override the visability of entire areas of your elevations and change their apperance to halftone or their lineweights.
Tue, Sep 25, 2007 at 7:20:04 PM | line weights in section
eldados
eldados Avatar
4.5 Stars: 8 Votes
Good point WWhub.
check out what's new in Revit architecture 2008...
Integrator
KarelCAD
Wed, Sep 26, 2007 at 6:37:18 AM | line weights in section
kkohutek
kkohutek Avatar
4 Stars: 7 Votes
WWHub,
right after I posted it I tried different ways to change the line weights
it's true, there are other things to do than what I said.
hope it will change.
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit line weights
Wed, May 15, 2013 at 10:49:44 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Automatic Line Weights
Wed, Mar 31, 2010 at 6:30:48 AM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 0.9577
