68 Users Online (66 Members):
Forums >> Revit Building >> Tips & Tricks >> How do you host a railing to a sloped floor when the floor is not "typical"?
14 Posts No Rating |
I have tried so many work arounds and I have no idea how to make this work. I have a ramp that curves around a curved area. I need landings and I need everything to be where it is in the photos. I didn't do a ramp because those don't play nicely and won't allow me to freely make a curved ramp like this. How do I get the ramp to play nice? Is really the only way to do this is by faking it? It is a lot of work to make so many ramps like this, but how would anyone else do this? I am using Revit 2016 and as of right now I am just making it work in plan, but it most definitely does not work in elevation. Pleases help
![pijpiwo Avatar](user_avatar/187179.jpg)
![5 Stars: 25 Votes](/images/stars_5.gif) |
Is your floor sketched with spline or ellipse, a free form as you mentioned? Yeah, …the only thing I can suggest is to use the ramp tool and sketch the boundary lines (not run) with the arc segments. I think it would be the easiest. Use boundary lines, they will give you more sketch options.
You can do a ramp with the floor object as well. A lot of people prefer doing just that. Adjusting railings however, is a major pita, but possible. Ramps at least, will give you easy railing time.
Sloped railing on sloped floor/ramp |
Tue, Dec 9, 2008 at 9:25:00 PM
railing on slope won't go to exactly 3'-0" from the floor |
Thu, May 14, 2020 at 6:23:18 AM
Sloped landings in stairs |
Thu, May 1, 2008 at 6:25:18 PM
Attaching chairs to an extruded floor? |
Tue, Feb 23, 2010 at 6:03:05 PM
Staircase Railing cant extend to floor |
Wed, Mar 26, 2014 at 8:33:49 AM
Members: | 2017220 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
