64 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> beam system
Wed, Oct 14, 2015 at 2:13:19 PM | beam system
brewer60
Currently entering in a beam system for the project. There are several different types of beams or columns that I must use in the system. I have loaded all the families that I need into Revit as my teacher stated. When I try to go in and edit the beams in which I need to change it does not allow me to change to the type which I need. Do I have to draw in each beam as need and do away with the whole beam system.
Wed, Oct 14, 2015 at 3:28:58 PM | beam system
Sorry but your question is unclear.
Many structural beams in Revit are controlled by a type catalog.  You can load all or some of the types.   If you later need a different type, you need to go back to the library and load the type from there.
Thu, Oct 15, 2015 at 7:32:18 AM | beam system
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
A beam system can only be used with 1 type of beam, if you have multiple beams you will need to input them individually.
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:21 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:11 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:34 AM
Schdule of Beam System
Tue, Jan 4, 2011 at 5:45:13 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Page generation time: 0.6049
