51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Some Filled Region patterns showing solid
Fri, Oct 9, 2015 at 1:15:50 PM | Some Filled Region patterns showing solid
motodesign
Revit 2015
Tried in different views at different scales.
Creating Filled region in the same view, some work fine, like "Earth", but some show up solid with whatever color is chosen in the Edit Type Properties.  Notably "Gravel" shows solid.
Is this  bug in Revit 2015?
Anyone else encounter this issue?
Thanks!
Fri, Oct 9, 2015 at 1:20:38 PM | Some Filled Region patterns showing solid
Model patterns do not scale with the view scale but draft patterns do.   When you have a small scale, some drafting patterns become solid.
Think about it!  If you draw lines against each other you get a solid.
Fri, Oct 9, 2015 at 1:46:50 PM | Some Filled Region patterns showing solid
motodesign
I already stated that I tried in different views and in different scales and that some filled patterns work, in the same view.
For example, "Earth" works and "Gravel" does not.  They are both drafting patterns.
Fri, Oct 9, 2015 at 2:04:09 PM | Some Filled Region patterns showing solid
Change the scale of the view and watch what happens!
Fri, Oct 9, 2015 at 2:10:48 PM | Some Filled Region patterns showing solid
motodesign
I did!  the earth pattern changes scale and the gravel pattern does not!
Mon, Oct 12, 2015 at 1:56:34 AM | Some Filled Region patterns showing solid
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
Go to the properties of that filled region and see if the hatch pattern is a "Model Pattern" of "Draft Pattern".
Like WWHub stated, draft paterns change with scale and model patterns don't.
Tue, Oct 13, 2015 at 1:48:43 PM | Some Filled Region patterns showing solid
motodesign
You guys don't really read the posts, do you?
Tue, Oct 13, 2015 at 1:59:03 PM | Some Filled Region patterns showing solid
Obviously, you have NOT read our posts!  This is NOT CAD.  Revit has drafting hatches and it has model hatches.   Please read this then come back if you have a new question.
Tue, Oct 13, 2015 at 2:10:58 PM | Some Filled Region patterns showing solid
motodesign
Please see Post #3 and attached image.
Tue, Oct 13, 2015 at 3:01:03 PM | Some Filled Region patterns showing solid
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Can you upload this pattern in question, so we can take a look?
Tue, Oct 13, 2015 at 4:04:47 PM | Some Filled Region patterns showing solid
#11
moto - Show us a image clip of your model gravel pattern.  MODEL! Like the attached image.
Filled region within detail family not showing in design option
Sun, Sep 21, 2014 at 7:24:47 PM
Problem with filled region
Mon, Apr 4, 2016 at 11:26:18 AM
Filled region showing up in an underlay
Fri, Dec 8, 2006 at 5:11:23 PM
"Solid white" filled region that prints in black
Mon, Aug 1, 2005 at 8:47:28 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:34 PM
Page generation time: 1.9029
