62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> "Tunnel" from AutoCAD file
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
I was asked to take the attached autocad file and create what is essentially a sweep to form a type of "tunnel". There are a TON of points that come in from the AutoCAD file, anyone know if an easy way to turn these lines into into a solid shape?
I think you limit that to a cross section and simplify it. If you rotate the back view somewhat, you have a fairly simple form wit sloping sides, rounded corners and a flat top and pottom. Four lines and 4 curves.
So you're saying to re-draw the lines as basiaclly a box with rounded corners?
How to construct a freestanding tunnel? |
Thu, Nov 24, 2011 at 3:02:46 AM
Linked AutoCAD file printing grey |
Mon, Jul 26, 2010 at 10:07:25 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:33 AM
File is "past it's end" |
Wed, Dec 19, 2007 at 9:35:12 AM
"File not saved" |
Mon, Nov 26, 2007 at 5:41:46 PM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
