Forums >> Revit Building >> Technical Support >> Using 2d group for Wall section, section details called out from wall section?
5 Posts No Rating |
I use Revit 2014 Architectural. Just want to know how you guys deal with wall sections & section details called from the wall sections.
When I cut a wall section from the Revit model, I draw 2d items over model walls, windows & ets. and I group the items because it's easier to control. If I made any callouts from the wall section, I paste the group "align in current view" in the callout views. By doing that, if I change the anything in the 2d group, both wall section & section detail (the callout) will be updated at the same time.
It works fine except I have concerns if the groups makes the model size bigger. Also, different scales of the wall section & section detail cause some lines show fine in the bigger scale (ex. 3"=1'-0"), but congest in the small scale (ex. 1/2" = 1'-0")
My process is in this post. I really try to use as little 2D work as I can.
As far as the grouping goes, groups do not necessarily make your model larger. However, you should never be grouping elements that are only used once.
5 Posts No Rating |
Yeah, thanks WWWHub. I try to minimum 2d elements as much as possible. Most 2d groups inlcude 2d window, door, membrane, flashing & etc. It's good the group does not necessarily increase model size.
wall section sample |
Fri, Jan 20, 2006 at 5:38:47 PM
section tags for broken wall sections |
Fri, Dec 7, 2007 at 10:57:26 AM
RAC 2009 - detail groups and section detail blow-ups |
Fri, Mar 26, 2010 at 8:50:54 AM
The option to create Wall section not showing up, only building section. |
Wed, Jan 23, 2013 at 3:16:47 PM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:26 AM
Members: | 2116792 | Objects: | 23196 | Forum Posts: | 152298 | Job Listings: | 3 |
