65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> When you can't make all walls join correct, what you do?
Thu, Sep 24, 2015 at 10:04:09 AM | When you can't make all walls join correct, what you do?
rabbitcookies
It seems impossible to make all walls join correctly. What's the method you use to make the incorrect joints looking good graphycally on the sheets?
thank you,
Thu, Sep 24, 2015 at 10:07:47 AM | When you can't make all walls join correct, what you do?
It is entirely possible.  Please read your HELP here.
Thu, Sep 24, 2015 at 10:15:14 AM | When you can't make all walls join correct, what you do?
rabbitcookies
Yeah, thanks for the link. I mean, how we fake it... some walls just take too long to fix.
Thu, Sep 24, 2015 at 10:32:31 AM | When you can't make all walls join correct, what you do?
It takes awhile to understand how wall joins work so keep trying to learn rather than faking.
The biggest problems are:
  • not understanding wall layers (see layer function - here )
  • sketched walls (sketched walls cause wall join problems.   splitting the wall horizontally to remove a sketch area often helps.)
  • having one wall try to join another wall that is a different height ... and possibly with different walls above or below.  Again, splitting the wall horizontally can help here.
When you are using the wall joins tool, pick only the 2 walls to be joined then use the temporary eye glass to isolate them first.
Thu, Sep 24, 2015 at 1:20:34 PM | When you can't make all walls join correct, what you do?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. . . . I might also add that when walls are 'Attached' to roofs and floors both Above and Below can cause problems that I have founf not fixable and just live with an ugly none mitred connection. Taking the 'Attach' aspect off temporarily just to see if it helps will reveal it is what's causing the anomoly.
Thu, Sep 24, 2015 at 2:21:20 PM | When you can't make all walls join correct, what you do?
rabbitcookies
Thank you guys. Do you feel like stacked walls are worse than regular walls on joining each other?
Thu, Sep 24, 2015 at 2:31:31 PM | When you can't make all walls join correct, what you do?
A stacked wall is really 'stacked' wallS.  More than one wall so a stacked wall that is 20' high joining a single wall that is 20 ' high will have problems like I discussed earlier.  THis is where you can horizontally split the single type of wall so that it can join differently with the different portions of the stack.
I think stacked walls are great for beginning of a project but I typically break them up when I'm in construction documents.
Thu, Sep 24, 2015 at 2:55:47 PM | When you can't make all walls join correct, what you do?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes . . . agrred.
Thu, Sep 24, 2015 at 3:47:51 PM | When you can't make all walls join correct, what you do?
rabbitcookies
I see how you guys deal with that. I was quite in a dilemma between using staked walls & regular walls. I have stacked walls from day one but more toward to split them to regular walls, but was wondering if it's worth to do that since it will take some time.
Thank you!
Thu, Sep 24, 2015 at 3:55:25 PM | When you can't make all walls join correct, what you do?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
My experience with Stacked Walls (that are left intact) is to not expect perfection unless under very basic conditions.
Fri, Sep 25, 2015 at 7:15:15 AM | When you can't make all walls join correct, what you do?
It takes no real time to 'brek up' stacked walls.   Just right click on them and choose "break up".
Fri, Sep 25, 2015 at 12:08:07 PM | When you can't make all walls join correct, what you do?
rabbitcookies
Wow, thank you! I didn't know that!
Wed, Oct 7, 2015 at 10:43:56 AM | When you can't make all walls join correct, what you do?
#13
rabbitcookies
Do room seperatiion lines affect wall joints? For the project's purpose I have to draw some room seperation lines overlapping with walls. Will it affect?
I tried to delete those lines and join the walls. It doesn't seem helping. Anybody has past experience on this?
Thanks,
Wed, Oct 7, 2015 at 11:13:24 AM | When you can't make all walls join correct, what you do?
#14
Room seperation lines have no affect on wall joins.   You have other issues - probably above or below your field of view.
Wed, Oct 7, 2015 at 12:43:57 PM | When you can't make all walls join correct, what you do?
#15
rabbitcookies
Thank you!
walls won't join
Fri, Oct 31, 2008 at 2:31:34 PM
Revit Can't cleanup walls with Modified vertical structure
Fri, Mar 7, 2014 at 11:34:31 AM
walls overlap but dont join.
Sat, Jul 30, 2016 at 5:13:59 PM
90degree wall join
Sun, Aug 20, 2006 at 9:08:55 PM
un-join walls
Wed, Mar 15, 2006 at 6:29:54 PM
Page generation time: 1.2656
