96 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> floor height tag in reflected ceiling plan (2015)
Wed, Sep 23, 2015 at 6:23:22 PM | floor height tag in reflected ceiling plan (2015)
ledgewood33
I would like to know if there is or can be created a floor tag that resembles a ceiling tag that measures the height of the bottom of the floor in the reflected ceiling plan?
Thu, Sep 24, 2015 at 7:13:37 AM | floor height tag in reflected ceiling plan (2015)
You can't create a floor tag to do this but a spot elevation tag will tag the elevation of the bottom of the slab.
Thu, Sep 24, 2015 at 9:16:45 AM | floor height tag in reflected ceiling plan (2015)
ledgewood33
is there anyway to modify the look a spot elevation tag? I would like it to look like our ceiling tag.
Thu, Sep 24, 2015 at 10:06:23 AM | floor height tag in reflected ceiling plan (2015)
I suggest you try.....
BTW - There is no way for a spot elevation to read a family name like a normal ceiling tag or floor tag does.
Thu, Sep 24, 2015 at 10:40:29 AM | floor height tag in reflected ceiling plan (2015)
ledgewood33
I am not sure I am following the last comment on this thread.
Thu, Sep 24, 2015 at 12:36:13 PM | floor height tag in reflected ceiling plan (2015)
You said you want it to look like "your ceiling tag".   We have no idea what that looks like.  I have tags that are just ceiling height but my preferred tag has the ceiling family name (like 2x4 SUSP CL'G  ) with the ceiling height AFF.  We don't know what you want but this will NOT be a ceiling tag, it will still be a spot elevation.  Anything other than the elevation will be dumb - not smart.   So lets say you want the tag to say "EXPOSED STRUCTURE / 8'-0" AFF", you would have to add the text portions and the elevation could be read (smart).
Edited on: Thu, Sep 24, 2015 at 12:36:45 PM
Thu, Sep 24, 2015 at 12:46:35 PM | floor height tag in reflected ceiling plan (2015)
ledgewood33
my apologies. I am attaching the ceiling tag that we use. it gives the height
Thu, Sep 24, 2015 at 1:16:12 PM | floor height tag in reflected ceiling plan (2015)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
There is a new Floor Properties for Elevation at Top and Elevation at Bottom. As long as the floor is flat then you get a good value otherwise is says 'varies'.
So I opened your ceiling tag family, changed the Category to Floor and the Label to be Elevation at Bottom and it workd.
See attached modified family.
Thu, Sep 24, 2015 at 2:26:51 PM | floor height tag in reflected ceiling plan (2015)
ledgewood33
thank you.
is there a chance you can save this family in 2015?
Thu, Sep 24, 2015 at 4:02:15 PM | floor height tag in reflected ceiling plan (2015)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Floor Elevation properties are not availalbe in 2015. New in 2016.
Thu, Sep 24, 2015 at 4:16:39 PM | floor height tag in reflected ceiling plan (2015)
#11
ledgewood33
no worries. thank you for doing this. the person in the firm who was having this issue is actually using 2016
Tue, Mar 9, 2021 at 10:22:12 AM | floor height tag in reflected ceiling plan (2015)
#12
LauraC2
I am in Revit 2021, I used the elevation at bottom. It is giving me the height from first floor not the level the ceiling is on. Any suggestions?
Thu, Mar 11, 2021 at 2:26:55 PM | floor height tag in reflected ceiling plan (2015)
#13
marmiketin1
4.5 Stars: 10 Votes
Make sure the ceiling is set to the correct floor level and then ensure the tag is using the "Height Offset from Level Parameter" for the label within the tag family.
Edited on: Thu, Mar 11, 2021 at 2:27:59 PM
Fri, Mar 12, 2021 at 3:36:33 PM | floor height tag in reflected ceiling plan (2015)
#14
LauraC2
Thanks but we are speaking of the bottom of a floor ceiling assembly, not a "ceiling"...
Fri, Mar 12, 2021 at 3:49:52 PM | floor height tag in reflected ceiling plan (2015)
#15
You are not telling us much.  First you say "... the level the ceiling is on"  now you say "...not a "ceiling".
We are architects and we should communicate better than that.
From what I have read, I am going to guess and ask "Do you just have an exposed structure and not a ceiling?"
If that is the case, Revit has always had a solution.  You can put a ceiling in to host your lights and other ceiling mounted elements but that ceiling has no properties.  It is in essance, just a plane and that cn be tagged with a height.
Callout Tag - referencing a floor plan - reflected ceiling?? (2010)
Wed, Nov 11, 2009 at 1:08:38 PM
Different Plan Title for Reflected Ceiling Plan
Mon, Aug 1, 2022 at 4:28:33 PM
Ceiling tags: how can i make them visible in floor plan views
Thu, Dec 6, 2012 at 3:59:35 PM
2015 wall height
Fri, Jul 10, 2015 at 9:17:02 AM
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Page generation time: 0.9023
