85 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Where do model patterns go?
Wed, Sep 23, 2015 at 2:01:39 PM | Where do model patterns go?
revitape
revitape Avatar
4.5 Stars: 9 Votes
Let's say you download a Revit project file that has a bunch of walls/floors/ceilings with model patterns on them. You copy those into your project. Everything is great except you want to change the scale of those model patterns.
Which leads to my question... where can you find those model patterns to now re-import it?
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Wed, Sep 23, 2015 at 2:34:36 PM | Where do model patterns go?
3.5 Stars: 395 Votes
Only the pattern definition is loaded, there is no associated txt file.   Sorry - you need a txt file to change the scale.
Wed, Sep 23, 2015 at 2:36:41 PM | Where do model patterns go?
revitape
revitape Avatar
4.5 Stars: 9 Votes
That's crazy that something can be in your project that was created from a .txt file but there is no way for you to source it. curse. Thanks anyway WW!
Wed, Sep 23, 2015 at 2:58:23 PM | Where do model patterns go?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Take a look at this and this.
Wed, Sep 23, 2015 at 3:29:05 PM | Where do model patterns go?
revitape
revitape Avatar
4.5 Stars: 9 Votes
this... is... BRILLIANT!
Thanks a ton!!!!!
Wed, Sep 23, 2015 at 9:51:47 PM | Where do model patterns go?
hugh
3.5 Stars: 4 Votes
The HatchKit Add-In for Revit exports patttern definitions from Revit via HatchKit directly to text .PAT files.
If the purpose is to resize the patterns then this can be done within HatchKit and the rescaled patterns imported directly to Revit.
Edited on: Wed, Sep 23, 2015 at 9:52:52 PM
Hugh Adamson
www.hatchkit.com.au
Thu, Sep 24, 2015 at 1:37:47 PM | Where do model patterns go?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes I'd agree that it's a shame you have to spend $90 for the Hatchkit add-on just to edit a pattern. I hope the upgrades are free when the new REVIT version comes out. Especially when you only use the tool a couple times a year.
This methed is crazy but worth trying http://notanotherrevit.blogspot.ca/2012/01/tip-extracting-pat-files-from-revit.html
Thu, Sep 24, 2015 at 8:26:19 PM | Where do model patterns go?
hugh
3.5 Stars: 4 Votes
Hi dgcad,
Thank you for the opportunity to clear up some confusion.
HatchKit is not an add-in for Revit.  It is a standalone hatch pattern editor available for many differing CAD systems.
There is no compulsion to purchase a licence, simply a value proposition like Revit itself apart from any necessity to purchase annual versions to keep up with changing file formats. That one-time price provides three installations. We offer other forms of license to address differing requirements, but only the Demonstration Version is free.  No other package graphically edits patterns.
You hope correctly. Again, HatchKit currently offers perpetual licenses and will work alongside any Revit version. HatchKit and Revit can connect via a free add-in where one is available. Our add-ins for Revit 2013, 2014, 2015 and 2016 are freely available from Autodesk's Exchange and from our website. We plan to provide an add-in for Revit 2017, again for free.
And if you seldom need to use it, you may find its relearning curve shorter than the method that you linked to.
Hugh Adamson
www.hatchkit.com.au
Thu, Sep 24, 2015 at 8:50:20 PM | hugh
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Quoting hugh from 2015-09-23 21:51:47
HatchKit is not an add-in for Revit.  It is a standalone hatch pattern editor available for many differing CAD systems."
So is it an add-in or not ? and what does it cost ?
Edited on: Wed, Sep 23, 2015 at 9:52:52 PM"
Edited on: Thu, Sep 24, 2015 at 8:51:24 PM
Thu, Sep 24, 2015 at 9:37:41 PM | Where do model patterns go?
hugh
3.5 Stars: 4 Votes
HatchKit is not an add-in. HarchKit.exe is is a stock-standard Win32 PE executable file, licensed as described on the website below my signature.
The four current versions of the quite separate HatcKit Add-in for Revit 2013 through 2016 connect Revit to your licensed Hatchkit. The Add-ins are provided totally free of cost and contain some fill management functionality such as being able to change a fill type from DRAFTING to MODEL or viceversa as well as acting as a HatchKit connector.
But you need not install an Add-in to run HatchKit. In fact Revit LT users cannot. Revit 2012 users cannot.
Nor do you need install HatchKit to run the HatchKit Add-In for Revit to pick up on its embodied fill management tools.
hope this helps.
Hugh Adamson
www.hatchkit.com.au
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:19 PM
Material cut patterns
Mon, Sep 19, 2016 at 8:56:36 PM
Fill Patterns Drafting / Model
Tue, Sep 8, 2009 at 8:06:40 AM
Loading Model Patterns
Wed, Sep 20, 2006 at 9:39:01 PM
Model Patterns
Wed, Dec 12, 2007 at 3:38:41 PM
Page generation time: 3.7180
