161 Users Online (160 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Importing old Font
Wed, Mar 29, 2006 at 1:37:16 PM | Importing old Font
ArchWestCY
4.5 Stars: 7 Votes
The firm that I work with has been using the same font for 20 years. Arch.shx is not a Word True Type font. I am setting up our Revit template and titleblock and need to find a way to import this font into Revit. Any ideas, or am I stuck with Word fonts? Chris This is my first post on revitcity.com. I look forward to working with all of you and this great software.
Tue, Sep 11, 2007 at 7:07:48 AM | Importing old Font
notagain
notagain Avatar
4 Stars: 1 Votes
well I am in the same boat....any takers on this subject
I really want this to work...some good things some bad
Tue, Sep 11, 2007 at 8:46:25 AM | Importing old Font
coreed
coreed Avatar
4 Stars: 16 Votes
you will have to find a True Type Font that's similar to the Arch.shx . As far as i know you will not be able to access any .shx fonts in Revit. only Windows installed fonts are accessable
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Sep 11, 2007 at 9:20:20 AM | Importing old Font
ArchWestCY
4.5 Stars: 7 Votes
I did eventually find a True Type Font that matched close enough.  We are now using ARchitxt.ttf with all of our software, Revit and AutoCAD alike.  This font is very similar to the Arch.shx font that we used before.  If you do a search on this site (in the Forums) you should be able to find it for download.
Good Luck
ArchWestCY
Tue, Sep 11, 2007 at 9:28:43 AM | Importing old Font
notagain
notagain Avatar
4 Stars: 1 Votes
cool....but I still need a solution....see I am going from an Intergraph product to Microstation to Revit and back....a close match will not do....
Tue, Sep 11, 2007 at 9:32:30 AM | Importing old Font
ArchWestCY
4.5 Stars: 7 Votes
The only advise I have is to use the ARchitxt.ttf font for all of them.
ArchWestCY
Importing a font into Revit
Thu, Jan 30, 2020 at 6:14:16 AM
dwg importing problem
Wed, May 28, 2008 at 8:52:31 AM
Importing Text from AutoCad
Thu, Sep 2, 2010 at 12:50:24 PM
Autocad model importing.
Wed, Nov 29, 2006 at 8:44:39 AM
CIS/2 exporting and importing
Tue, Feb 26, 2008 at 7:42:53 PM
Page generation time: 1.7553
