Forums >> Revit Building >> Technical Support >> Sheet numbers??
Fri, Jul 16, 2004 at 10:12:53 AM | Sheet numbers??
jstewart
Has anyone figured out a way to add sheet numbers that can automatically update when you add or remove a sheet? SHEET NO. 1 OF 30 SHEET NO. 2 OF 30 SHEET NO. 3 OF 30 Post edited on 2005-01-13 11:45:38
Thu, Sep 7, 2006 at 4:50:18 PM | RE: Sheet numbers??
dbruck
I am resurrecting this original question from a while back to see if anyone has figured this out since it was originally posted. I am currently redoing my title blocks and would like to be able to add an automatic numbering of sheets in the set as noted, i.e. "Sheet 1 of 30, Sheet 2 of 30..."
Thu, Sep 7, 2006 at 5:40:50 PM | RE: Sheet numbers??
eldados
eldados Avatar
4.5 Stars: 8 Votes
so if you add or remove sheets is it still going to be out of 30?? i can't see an automatic way of doing this... you could add 30 to your title sheet and manually through the drawing list you can add a number...
Integrator
KarelCAD
Tue, Feb 20, 2007 at 5:50:57 PM | Sheet numbers??
NIDOarc
I am trying to link to project files together, and create one integrated index.  The team made a project filr for the north building and one for the south.  They are both in one CD set... so I need floor plans for  norht to follow south..  ceiling plans nrth then south etc.  i also need to type in consultants sheets....
Oh and I am a newb to Revit as well as this forum... i.e. this is my first task in revit.
 Thanks....
Wed, Feb 21, 2007 at 12:43:47 PM | Sheet numbers??
3.5 Stars: 395 Votes
See these discussions:
ttp://forums.augi.com/showthread.php?t=53397&highlight=drawing+schedule
http://forums.augi.com/showthread.php?t=55283&highlight=drawing+schedule
http://forums.augi.com/showthread.php?t=30376&highlight=drawing+schedule
ODBC Export with Sheet Names and Numbers
Tue, Aug 12, 2014 at 9:54:33 PM
view names and sheet numbers
Wed, Oct 25, 2006 at 5:54:49 PM
My Section Detail and Numbers will not display on sheets. Can anyone tell me why
Fri, May 21, 2010 at 5:09:18 PM
View numbers or detail numbering
Wed, Oct 13, 2010 at 11:24:50 AM
Opening numbers
Mon, Dec 19, 2005 at 3:07:29 AM
Page generation time: 0.5794
