40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Jeep family won't render
51 Posts No Rating |
Anybody else have problems rendering the Jeep family from this site. When I try it just comes out all white, no materials. I have materials all defined for it but it just doesn't seem to work.
The jeep family uses an import 3D CAD file.
Problem solved.
The jeep family on this site doesn't have proper materials assigned to the objects. I eventually had to redefine the material assignments in the family and then go into my project and delete the family AND its incorrect materials before loading the corrected family.
If you just purge the old family and not the associated material objects the new family will inherit the the old materials because the objects share the same name.
Confused?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
the jeep was created on someones computer using it's own maps which are pathed back to the library which you don't have on your computer which in return defaults to generic material...
more confused %)??
Jeep J10 Honcho |
Wed, Sep 22, 2010 at 12:46:38 PM
Mullions won't render |
Wed, Jun 24, 2009 at 4:09:30 PM
Lights won't turn on for exterior render |
Wed, Mar 16, 2016 at 6:03:04 PM
Images won't render! |
Thu, Sep 4, 2008 at 3:36:22 PM
RPC's won't render in 3DS Max after importing from Revit |
Sat, Dec 17, 2005 at 9:10:50 AM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
