53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Light Fittings in Legend
Mon, Sep 14, 2015 at 7:11:33 AM | Light Fittings in Legend
geraldrogers
Is there a way to show light fittings in a RCP legend as they appear in a RCP view? i.e. viewed from below.
The legend shows the light viewed from above whereas the RCP shows the light fitting viewed from below, so they don't look the same. Confusing for anyone trying to read the legend!
Gerald Rogers
Revit 2015
Mon, Sep 14, 2015 at 8:36:29 AM | Light Fittings in Legend
3.5 Stars: 395 Votes
Set your legend component view correctly.
Mon, Sep 14, 2015 at 10:46:17 AM | Light Fittings in Legend
geraldrogers
That view direction isn't available for the lighting components. Only floor plan and elevation front and back is available. How do I add the choice for a ceiling view?
These are Philips light fittings downloaded from their website.
Gerald Rogers
Revit 2015
Mon, Sep 14, 2015 at 11:12:37 AM | Light Fittings in Legend
As you can see from my image, that view IS AVAILABLE for lighting components unless maybe they were built wrong.  Post one of the families you are using - maybe we can make some recommendations.
Tue, Sep 15, 2015 at 2:34:00 AM | Light Fittings in Legend
geraldrogers
Here is one such fitting. They are all downloadable from the Philips website.
Gerald Rogers
Revit 2015
Tue, Sep 15, 2015 at 10:02:23 AM | Light Fittings in Legend
That family was not built to Revit conventions for a ceiling light and it is poorly done.  It does not work correctly to cut the host ceiling and component visibility is not set correctly.
Tue, Sep 15, 2015 at 10:18:33 AM | Light Fittings in Legend
geraldrogers
That is not very satisfactory from a major international lighting supplier! You would expect that Revit models from large manufacturers would be built correctly?
Edited on: Tue, Sep 15, 2015 at 10:20:26 AM
Gerald Rogers
Revit 2015
Tue, Sep 15, 2015 at 12:43:39 PM | Light Fittings in Legend
Where did you get that fixture?   I don't see it on AutoDesk Seek and not on the website I looked at.  It is built to metric standards and I see you are from Ireland.
Manufacturers have been relatively slow at developing Revit families but at least they are trying.  Many of the first families were just ported CAD and were terrible.  The tried to model this family so that it could be used on any reference rather than only ceiling hosted.   But as you have seen, it has other problems.
I suggest you send a complaint to the manufacturer.
Tue, Oct 6, 2015 at 5:51:30 AM | Light Fittings in Legend
geraldrogers
http://www.lighting.philips.com/main/support/support/revit-library.html
what do I need to say to the manufacturer regarding the REVIT models in order to explain clearly what is wrong with them?
Are there guidelines I can direct them to?
Gerald Rogers
Revit 2015
Tue, Oct 6, 2015 at 10:41:28 AM | Light Fittings in Legend
That webpage seems to have some troubles.   Some of the lights download whereas others take you to another page and no download.  I would complain about that first.
Of the ones I was able to download (not yours), the light seemed to be built correctly as ceiling lights and would cut its host.
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS
Thu, Dec 15, 2005 at 10:30:38 PM
Legend View Range
Mon, Jan 27, 2014 at 8:46:21 AM
2D light family shows too big on RCP legend
Wed, Jul 3, 2013 at 11:35:44 AM
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:49 PM
how do i make a light shine a different colour?
Tue, May 27, 2008 at 7:21:38 AM
Page generation time: 0.3604
