56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> ::--:: Roof Plan in Wireframe ::--::
Wed, Mar 29, 2006 at 11:09:29 AM | ::--:: Roof Plan in Wireframe ::--::
audisnapr
3 Stars: 6 Votes
hey guys... it's been several years since I've been here on the boards, but I came across a problem I just can't solve. for whatever reason, my roof plan will not hide it's lines - essentially, it is displaying in "wireframe", but all icons and view-properties show as "hidden line". Is there some place that I may have accidentally over-written this with a master switch? It's not happening to any of my other views. My view-range is set to the default properties. This originally happened to the roof plan I first created during the CD phase of my project. I couldn't solve it, but found the work around to be simply "duplicating" the view and using the new view... it would display correctly. But now, that new duplicated view is displaying incorrectly and is appearing as wireframe. Any suggestions? I'm on Revit 8.0. thanks guys. <edit> even "shading" or "shading with edges" appears as wireframe, but now with color. looks cool, but does nothing for my CD set :-/ Post edited on 2006-03-29 11:15:58
Wed, Mar 29, 2006 at 11:26:00 AM | RE: ::--:: Roof Plan in Wireframe ::--::
audisnapr
3 Stars: 6 Votes
well, I was able to get it to hide lines. I'm not sure what the "real" solution should be, but I applied one of the standard view templates and that seemed to fix it. Perhaps at some point a view template was applied that had "wireframe" as it's display type (unlikely though). This still doesn't explain why I was not able to hide the lines using the standard methods, ie: icon at bottom of view window, drop-down menu in the view properties dialog or the in the view drop down @ top of revit window???
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Roof plan
Fri, Sep 2, 2016 at 4:58:14 PM
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
Temporary wireframe
Thu, Aug 26, 2010 at 12:14:56 PM
Creating a Roof Plan in Revit
Wed, Oct 3, 2007 at 8:51:58 AM
Page generation time: 2.1555
