79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Title Block Images - Revit 2016
Hi,
I am about to create my custom title block in Revit. I want to put in images of the many associations that we are part of, like NICEIC, Gas Safe, that sort of thing under my company name.
What would be the best way to do this please? Raster Images or I could draw the Logos in AutoCad and then Import those in?
The drawing option will obviously take a little more time, But once I have them I can do what ever I want with them.
Cheers Guys
Swinny
Why don't you do a simple test and try out both.
BTW - I recommend that you don't import CAD in your titleblock. Use CAD to create Revit linework.
Cheers Hub,
Obvious really a suppose. I'm starting to learn that there is quite a bit of experimenting with revit. I went with Raster Image. It worked fine.
Great!
Yes, .... experimenting is the best way to learn Revit. You can always undo (if you hav not done a save). Also learn to use the HELP. It is far superior to anything you may nave seen with AutoCAD. Just do simple one word searches.
Title Block Images |
Wed, Sep 22, 2010 at 3:15:45 PM
In the default Revit Templates i couldnt find revit title block |
Fri, May 23, 2014 at 7:22:23 AM
Importing Arch. Title block with all info. |
Mon, Mar 30, 2009 at 4:55:02 PM
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:26 PM
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:43 PM
12
Members: | 2022458 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
