151 Users Online (149 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Openings--how do you control constraints?
Wed, Mar 29, 2006 at 9:21:12 AM | Openings--how do you control constraints?
sancho
Has anyone else had trouble controlling openings? When I try to change the dimensions of an opening I've created in a wall, the top constraint cannot be change to none, and the base constraint does not work either--very frustrating. Is there a trick to controlling openings?
Thu, Jun 11, 2009 at 10:00:42 AM | Openings--how do you control constraints?
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I can't be of any help here, openings are being a PITA in my project too.
I have a wall full of openings with curtainwall. When I placed them the other day I had no problem getting them to align to the windows, but now when I click on align the opening doesn't budge and I don't get the stretch arrows when I click on the opening as I did before.
Anyone have any clue what is going on? It's very frustrating.
TIA
Diane
It's got to be happy hour somewhere
Thu, Jun 11, 2009 at 1:51:27 PM | Openings--how do you control constraints?
I don't like the openings tool.
Most of the time, I use the edit profile to create an opening but that can cause other problems.  Another solution is to build a wall based family that has an instance base or type based controllable void that cuts your wall.  Or use the cased opening door family and remove the casing and give the door a number that will filter out in your schedules.
Thu, Jun 11, 2009 at 1:57:49 PM | Openings--how do you control constraints?
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I found that if I pulled the curtainwall away from the edge of the opening I was able to then use the align tool. :-/  Don't know why, but it worked.
I'll look into your suggestion in the future. Thanks
The best way to control top and base of the Wall is to modify the Constraints...
Mon, Jun 16, 2014 at 8:56:16 AM
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:14 PM
Constraints Are Not Satisfied when opening file - Revit Architecture 2008
Wed, Aug 27, 2008 at 9:46:30 AM
parametric extrusion sketch
Mon, Mar 5, 2012 at 12:16:27 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Page generation time: 0.4627
