71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> ROOM TAG AREA FORMULA
Hi,
is there any way to add a formula to room tag parameter so in the plan it will show not 100% area but for instance 97%?
I know I can change it in the area schedule but client asked me to show 97% areas in floor plans aswell.
Many thanks for any help
Luba
No formula's in tags - sorry.
I'm curious - what mandaes 97%? Where drives that number? Why not 95%? I'm Lost!
hah
we are working on big shopping centre and tagging retail units with areas. 97% or sometimes we show 95% are demonstrating the lettable areas with no internal walls or storage spaces.
I know figure 97 is riddick. (thats what our client demanded)
:D
Luba
2 Posts No Rating |
I might be wrong, but I don't see why you couldn't do this with a shared parameter. If you created a shared parameter and called it something like "Recalculated Area" and loaded it into your project, then you could let revit calculate the gross area and then for the recalculated area just apply a formula like "area/0.03" or something to that effect. You would have to create a custom tag at uses the Recalculated Area parameter.
I haven't tried this myself, but I've done similar things when I've needed specialized room tags.
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Revit 2010 family parameters formula and room tag |
Fri, Aug 7, 2009 at 4:28:34 PM
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Ceiling Height in Room Tag? |
Wed, Sep 10, 2008 at 7:04:19 PM
Room area calculation |
Sun, Nov 25, 2012 at 2:28:44 PM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
