147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adaptive Railing with Handrails
Wed, Sep 2, 2015 at 3:13:02 PM | Adaptive Railing with Handrails
Flagfoot
Using Revit 2015. I am new to adaptive components and pretty new to Revit. I am trying to get a railing profile to turn without tilting. By profile I mean the reference planes used to define the handrail and guardrail solids, not an actual profile family.
The guardrail and handrail are offset from the adaptive (placement) points. I got the solids to follow the slope of the stair, but am not sure how to get the profiles to remain vertical. I cannot think of a way to lock the profiles vertically while still allowing them to rotate on the X-Y plane.
Handrail component file and image of handrail issue are attached.
Wed, Sep 2, 2015 at 5:19:38 PM | Adaptive Railing with Handrails
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Why AC? What's wrong with the railing tool?
Thu, Sep 3, 2015 at 9:11:18 AM | Adaptive Railing with Handrails
Flagfoot
Thanks pijpiwo for the reply.
The stairs are not revit-generated stairs. They are modeled in-place and are classified as stairs, but do not have revit risers and landings. I haven't been able to get railings to work on the "stairs" yet.
However, if there is a way to get the railing tool to work on these "stairs," that would solve my problem too. So far we haven't been able to get railings to work on the "stair." That's why I tried to make an AC that I could place in such a way that it followed the "stairs" with their strange shapes and angles.
Thu, Sep 3, 2015 at 9:47:14 AM | Adaptive Railing with Handrails
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Host a rail to a floor(s) and apply slope and height correction as needed. See this.
Thu, Sep 3, 2015 at 10:41:33 AM | Adaptive Railing with Handrails
Flagfoot
Thank you I will try this.
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Revit Handrails
Thu, Oct 20, 2016 at 1:45:57 PM
Rvt 2013 Handrails for 3-run stair
Wed, Apr 5, 2017 at 1:59:55 PM
Handrails Flatten When Extended
Fri, May 29, 2015 at 1:11:10 PM
Sope independent railing
Tue, Aug 13, 2013 at 10:17:26 AM
Page generation time: 0.2914
