59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Showing a chimney breast in plan view
Wed, Mar 29, 2006 at 9:20:05 AM | Showing a chimney breast in plan view
Mulder
Does anyone know how to show a chimney breast in plan view, the detail level will be in course view as the plans are for leasehold, typically the chimney has a 350mm projection from the main wall & is 1500mm wide. Thanks
Thu, Mar 30, 2006 at 11:38:39 AM | RE: Showing a chimney breast in plan view
carlosgt
Tou have to create a new family (fireplace) Go to component, then pick create in place, and create a new family (Generic model) Then you have to build a fireplace going to solid and extrud it whatever height you want, then go to solid-void and create a void in the solid try to shape your fireplace according your dimensions. You can join your new family to the existing wall going to join geometry. Good luck.
Plan region not cutting component
Mon, May 7, 2012 at 10:04:57 AM
Santa Wants a Chimney
Wed, Sep 22, 2004 at 1:01:23 PM
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:33 PM
11
In shaded View walls/roofs are showing material and lines behind them
Tue, May 28, 2013 at 9:35:45 AM
Creating Families - bugs, limitations or my ignorance?
Mon, Apr 4, 2005 at 8:01:07 PM
Page generation time: 1.6161
