80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Sketchup to Revit
Wed, Sep 2, 2015 at 10:05:38 AM | Sketchup to Revit
lavendert8
I am currently working on a project and have been debating if I want to start it in Sketch up and then import it into Revit. If I do it that way will the walls be adjustable and will I be able to manipulate the elements in accordance with levels and other smart objects?
Wed, Sep 2, 2015 at 10:31:37 AM | Sketchup to Revit
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
My main questions would be why?  If your planning on manipulating it then just do it in Revit.  There's not a whole lot you can do once you import it.
Wed, Sep 2, 2015 at 10:31:43 AM | Sketchup to Revit
3.5 Stars: 396 Votes
DON'T DO IT!!!!  I recently tried to do a project with a skechup import thinking I could use some of the views that were highly developed.  Because the Architect that did the sketchup did not apply a lot of layer control to the sketchup elements, I couldn't control it in my views.  As the project developed, elements needed to move and to edit the sketchup would have been worthless.
There are no Revit elements in Sketchup and nothing will be parametric, adjustable, tagable or scheduled.  Sure, you can bring sketchup elements into a family and use them in Revit but otherwise, sketchup is worthless in the Revit world.
I know that sketchup is easy but there is a lot of that ability built into Revit.  I'm working very hard here to get our designers to work differently and use Revit like they do in sketchup.
Wed, Sep 2, 2015 at 11:16:17 AM | Sketchup to Revit
lavendert8
Thanks! I just wanted to make sure my suspisions were correct.
Wed, Sep 2, 2015 at 11:25:54 AM | Sketchup to Revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can do very preliminary design work using sketchup if you are comfy in that environment but you want to import that into revit and redraw it pretty quick and then scrap the SKP file. Sketchup models don't adhere to the REVIT view ranges or cut planes which is the single biggest problem.
I have seen many projects paralelled with an architect using sketchup while the production people use REVIT and it's not fun or pretty but believe it or not it can be done.
There will be no parameteric connectivity of course but you can overlay the two models in REVIT and try to visually recognize the changes.
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Sketchup To Revit Problems *Please Help*
Thu, Mar 12, 2009 at 9:21:29 AM
A little SketchUp with your REVIT ? [ 1 2 3 ]
Mon, Apr 13, 2009 at 3:06:13 PM
34
Page generation time: 2.0137
