64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> adjusting spacing while using "Use Baluster Per Tread On Stairs"
Tue, Sep 1, 2015 at 3:25:18 PM | adjusting spacing while using "Use Baluster Per Tread On Stairs"
ledgewood33
I am using the "Use Baluster Per Tread On Stairs" feature. while doing so I have said I want 2 balusters per tread. it spaces those balusters 4" apart. IBC says that I cannot have a 4" sphere that can fit through the balusters. up at the top of the edit baluster placement window I have the distance from previous set to a distance that complys with the IBC 4" sphere rule.
is there a way to adjust the spacing when the "Use Baluster Per Tread On Stairs" is checked?
Tue, Sep 1, 2015 at 3:40:35 PM | adjusting spacing while using "Use Baluster Per Tread On Stairs"
I don't understand.  2 ballusters per tread means you will get an even spacing for the entire length with two ballusters / tread.  It will not be an uneven spacing.  The 'distance from previous' is ignored when using the balluster / tread.
Tue, Sep 1, 2015 at 4:10:58 PM | adjusting spacing while using "Use Baluster Per Tread On Stairs"
ledgewood33
I was just doing the math and figured that I cannot get what I want to achieve. I have a (2) 2" wide balusters on a 12" tread. I would need them to be slightly bigger than 2" to achieve the IBC requirement.
Baluster per tread on curved stair
Thu, Apr 4, 2013 at 2:18:52 PM
non typical stairs
Wed, Jul 16, 2008 at 1:03:16 PM
How do you alter stairs in revit so that they could have a tread of 9" and riser
Fri, Sep 28, 2012 at 1:27:53 PM
TREAD BALUSTER
Tue, May 21, 2013 at 3:36:03 AM
Baluster Height Issue
Tue, Nov 6, 2007 at 6:37:15 PM
Page generation time: 15.8833
