63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> wall layer not wrapping for door family with jambs
I recently created a door family with jambs and in a plan view the wall layers do not wrap even though the wrapping layer is checked. there is something I did or didnt do when building the family and I can figure it out.
I am attaching a revit file that has the door family with jambs and an OOTB door that does have the wall wrap at inserts.
by the way I am using 2015
Does this explain your problem? Family properties.
apparently I did not have check when I thought it was. sorry for wasting everyones time
apparently I didnt have the "wrapping at inserts" checked when I thought it was. sorry for wasting everyones time.
is there a way to get a to wrap past a structure material at an insert
Wrapping walls at window jambs |
Tue, Apr 22, 2008 at 9:19:42 PM
Help required with wall wrap at window & door jambs |
Fri, Oct 16, 2015 at 4:57:19 AM
wrapping wall materials |
Thu, Aug 14, 2008 at 4:40:22 PM
Door Jambs |
Thu, Apr 6, 2006 at 2:51:28 PM
door with jambs and adj swing |
Thu, Feb 12, 2009 at 8:46:01 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
