59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stair Line Control
Tue, Mar 28, 2006 at 10:15:57 PM | Stair Line Control
tomdbiggs
OK. This is probably really simple, but I'm missing something. I'm doing a restoration of a 1885 large victorian. Stairs are existing, so I put them on this phase. They look fine on existing plans with the lines dashed 1/16" gap above the cut line. On plans for new phase the stairs show up as grey lines, but the lines above the cut are solid grey also. A very confusing mess. What is the solution to this problem I am experiencing? I looked for a parameter that might fix it but to no avail. Tom
Tue, Jan 9, 2007 at 4:04:00 PM | Stair Line Control
jeans
Open up the visibilty/ graphic overides and scroll down to stairs.  Un check the "stairs beyond cut line" and "stringers beyond cut line"  that should fix the problem.
Tue, Jan 9, 2007 at 4:17:26 PM | Stair Line Control
tomdbiggs
Thanks for the insite. That was very helpful.  I am surprised I didn't see that before!
Changing walk line
Tue, Aug 20, 2013 at 9:50:52 AM
Stair Cut Line : Double Line
Mon, May 18, 2015 at 3:19:09 AM
Stair Break Line Customization
Mon, Dec 12, 2011 at 4:20:10 AM
Stair break line problem
Fri, Jul 17, 2020 at 4:21:46 PM
Line weight control
Tue, Nov 21, 2017 at 2:14:40 AM
Page generation time: 0.9109
