117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revolve Axis
Tue, Mar 28, 2006 at 9:56:52 PM | Revolve Axis
cadjockey
Hi all, I have created a library part using a solid sweep revolve. I would like to add a parameter to this element which will allow me to adjust the angle of the axis after it has been imported into a project. Is this possible? If so how? cadjockey
Tue, Mar 28, 2006 at 9:59:58 PM | RE: Revolve Axis
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes of course. You would need to setup a reference plane with an angular dimension parameter on it then constrain the axis of the revolve in the sketch to this...
Tue, Mar 28, 2006 at 10:10:49 PM | RE: Revolve Axis
cadjockey
Hi Mr Spot, I tried to do this. It didn't seem to work. Can I confirm: Does the work plane of the revolve have a bearing on this constraint? Do I create the referance plane while I am editing the revolve and add the dimension also while in this mode? I can only see and manipulate the axis while in the edit mode. cadjockey
Wed, Mar 29, 2006 at 12:21:44 AM | RE: Revolve Axis
cadjockey
Mr Spot, OK I have the axis being controlled now by an angular dimension which is also a parameter I can manipulate. However, when adjusting the angle of the axis the revolve sweep changes its shape as well. Is the only way to stop this to apply dimension constraints? cadjockey
Wed, Mar 29, 2006 at 1:05:34 AM | RE: Revolve Axis
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just dimension constraints are the best way to constrain the shape.
Wed, Mar 29, 2006 at 1:23:52 AM | RE: Revolve Axis
cadjockey
Hi Mr Spot, Can arcs be used and constrained in a sweep revolve? I am finding that I can create a revolve in what ever shape however, when the axis is adjusted to a desired angle the arcs have a mind of their own. What I am trying to do is create the corner detail I showed in a recent thread, which is quite an organinc shape but without the radial lines. See attached. The shape you see has been successfully created using a segmented sweep however, each aris of the segments are visible. Creating a sweep revolve removes the radial lines but I loose in functionality. Any suggestions? cadjockey
Wed, Mar 29, 2006 at 2:46:10 AM | RE: Revolve Axis
cadjockey
No Problem. I solved it. cadjockey
Revolve along a curved axis?
Tue, Apr 1, 2008 at 3:40:01 PM
Creating a mass of globe/ Continents
Mon, Apr 30, 2012 at 12:42:26 PM
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Axis in elevation is funky
Wed, Mar 25, 2009 at 1:07:48 PM
using revolve tool to shape top of walls 'Revit 2012'
Wed, Feb 20, 2013 at 2:47:55 PM
Page generation time: 0.5605
