89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> curtain wall cuts when close to floor line
Thu, Aug 27, 2015 at 2:17:40 PM | curtain wall cuts when close to floor line
Warchitect
4 Stars: 5 Votes
Check out image. when I bring the curtain wall top close the the floor line above, it suddenly notches it, on the right side a little. See pic. I extended the wall above the floor to show it better. but it still occcurs when at the underside of the floor.
Thu, Aug 27, 2015 at 4:48:49 PM | curtain wall cuts when close to floor line
fastjohnnyz
You wouldn't by chance be stretching it up into a shaft opening?
Door that cuts a curtain and a normal wall at the same time
Sat, Jun 1, 2019 at 7:33:19 PM
Stepped Wall over Curtain Walls using Log Walls
Wed, Oct 2, 2013 at 3:22:02 PM
12
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:45 PM
curtain wall at column
Tue, Sep 8, 2009 at 12:24:41 PM
Curtain Wall Sill overhang when embedded within Walls
Tue, Jul 24, 2012 at 8:50:16 AM
Page generation time: 1.9138
