72 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair stringer slope doesn't match riser slope?
Fri, Aug 21, 2015 at 9:02:18 AM | Stair stringer slope doesn't match riser slope?
vanderloo
I can't figure out what controls the slope of the stair stringer but, as you can see in my attachment, the risers on this stairway are fine. But the stringers aren't at the same slope.The bottom run is ok but the upper run definitely isn't. Help. Thanks
Fri, Aug 21, 2015 at 10:30:14 AM | Stair stringer slope doesn't match riser slope?
This is a process issue - we would have to see how you created these and the properties.  Way too much information to verbally discuss.  Copy all of this to a new file then purge that file 3 times to get rid of everything else and post it after saving.  Also include what Revit your file is.
Stair - end riser flush with stringer
Tue, Mar 3, 2009 at 5:57:58 AM
Roof's wont slope :(
Mon, Apr 2, 2007 at 5:34:05 PM
Stair riser at floor connection
Tue, Jul 31, 2007 at 11:51:27 AM
Stair Stringer connections
Wed, Jan 14, 2015 at 11:14:39 AM
Stringer Haunch (level off) at top of flight
Wed, Dec 14, 2011 at 2:03:06 PM
Page generation time: 3.1393
