Forums >> Revit Systems >> Technical Support >> Issues with Pipe elevation tagging
Thu, Aug 20, 2015 at 4:37:21 PM | Issues with Pipe elevation tagging
cwells8088
I'm having some troubles with the elevation tags on my pipe for the second floor of my project. The pipes themselves are have heights set relative to the second floor (though this drawing is ref: level Mezzanine,  -2' off). If I select the pipe, height is listed relative to the 2nd floor slab, but when I tag them with my elevation tag, they only reference the base elevation for the project. I know about fixing the relative height for normal spot elevation tags but I don't know of a similar option on the family tag I'm using, which is a pipe tag. Any ideas? I've attached an image with the pipe properties pulled up, but I'm pretty lost going forward. Any help much appreciated, thanks!
Mon, Aug 24, 2015 at 8:23:31 AM | Issues with Pipe elevation tagging
Pikachu123
We usually place a spot elevation tag below the tag, because our elevations are always ttop the bottom of pipe, and if you incorporate the "Invert Elevation" parameter to the tag, it is not the same value of a elevartion. See attached. The annotation on the right is a invert elevation tag. The one on th eleft under thte size tag, is a spot elevation. The elevation of the pipe is 8'-0". No insulation.
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Centerline elevation of pipe below underside of floor above
Mon, Dec 22, 2014 at 8:11:21 AM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:03 AM
Thu, Aug 27, 2009 at 6:26:27 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Page generation time: 0.4611
