56 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> How to attach top/base - walls to mass roof
19 Posts No Rating |
Hello,
I have created a few mass roofs in my project to achieve a custom roof profile in Revit 2015.   See attached image.) I started by creating a mass in model and then converted it into a solid mass roof. However I cannot select the roofs when I go to attach my walls with the "Attach Top/Base" command. Any idea how to do this?
Thanks,
Megan
Edited on: Tue, Aug 18, 2015 at 11:37:41 AM
If you had used the standard model in-place tools and assigned the family to roof category, then the attach tool works.
Maybe I didn't assign it as a roof properly. I assigned it in the properties dialogue box when I clicked "Edit in Place" in the Modify Tab. This was after I already built the mass. It was originally defaulted as a floor.
How should I have done it?
Edited on: Tue, Aug 18, 2015 at 5:43:33 PM
I rarely ever use a mass except in the conceptual enviroment. So I don't know what problems occur with switching.
I simply start the model-in-place process and set my category first. I know that works in this instance because I tested it to make sure.
How do you set the category? Are you using the "in place mass" tool? I can't seem to make it a roof and not the default floor.
When you start a model-in-place family, the family category interface pops up automatically.
Revit newbie - Tapered circular column will not attach top/base properly |
Thu, Aug 22, 2013 at 5:26:46 PM
Walls will not connect to ceiling or roof |
Mon, Mar 2, 2015 at 8:25:47 AM
Problem: cannot attach truss top to the roof |
Fri, Oct 26, 2012 at 4:43:31 AM
Roof by Face and Wall by face tools |
Tue, Jan 28, 2014 at 6:31:03 AM
Problems with the Attach Top/ Bottom Tool |
Tue, Apr 29, 2014 at 10:38:24 AM
Members: | 2017243 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
