72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> scheduling door finishes and materials
Thu, Aug 13, 2015 at 12:37:33 PM | scheduling door finishes and materials
lpluger21
Hi Everyone,
I am recreating my offices door and window schedule in revit 2015 and I am just about there but I am having an issue with scheduling the finishes. The frame material is a pre determined field in revit so that was easy. Our doors and frames are always the same material so I made a calculated value for that no problem. But where I run into an issue is getting independent interior and exterior door finishes. I am fine with having to enter the information manually in the schedule, but I can't figure it out. I have attached our CAD version so you can see what I am going for and also what I have so far. Any suggestions would be helpful. Thank you!
Thu, Aug 13, 2015 at 12:56:31 PM | scheduling door finishes and materials
You can add shared parameters to your project (AND TEMPLATE) for this data or it can simply be an added schedule parameter.
Thu, Aug 13, 2015 at 2:54:53 PM | scheduling door finishes and materials
lpluger21
Thank you! I got it working with your solution.
How to Hide Door Transition Strip with Materials Finishes in RCP (Revit 09)
Thu, Sep 4, 2008 at 4:13:16 PM
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Finishes schedule with materials spec in it
Tue, Jun 5, 2012 at 1:42:43 PM
Door Finishes - Scheduling & Rendering
Tue, Nov 18, 2008 at 10:10:19 AM
Materials vs Finishes question - where does information go?
Thu, Jan 5, 2012 at 11:35:32 AM
Page generation time: 0.7803
