Forums >> Revit Building >> Technical Support >> filled regions...
a while back i represented some brace frame locations with a simple filled region. i have since located the frames' elements, and no longer need the 'hatching'. however, i cannot locate/tab through to the outline. if i drag a box over the entire filled region, it will not select it. the only thing i can think of is that i changed the cut plane, would this affect my filled regions. all of them are without a perimeter line and i can select none of them.
any assistance/advice would be appreciated. Thank you!
Have you tried turning different elements off?
Sorry can't be of more help.
Macca Sunshine Coast QLD Australia |
I once had something happen to me in very similar fashion, on an earlier release of Revit, 7.0 i think it was, it may have been 6.1. Anyhow, the same thing happened to me, and no matter what I did, I could not get to that filled region, yet it would show in every print. I finally ended up creating a duplicate view, and then copy-paste all the annotations and other detail elements into the new view. I then erased the old view entirely. It was almost as if the old view was "damaged" in some form, and could not be repaired. Anyways, the method I stated above took about 4 seconds, and it solved the issue. Submitted that problem to Autodesk, and never heard back from them...
27 Posts No Rating |
I found the problem. Thin lines, used to create the region, had been turned off.
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:28 AM
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:30 PM
Filled Regions on an elevation |
Wed, May 25, 2005 at 1:35:39 PM
Revit 2014 Filled Regions |
Fri, Jun 27, 2014 at 4:47:57 PM
11
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:56 PM
Members: | 2101693 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
