Forums >> Revit Building >> Technical Support >> Who changing of tree's size NEVER work?
Why changing of tree's size NEVER work?
https://www.youtube.com/watch?v=xHBwqcyrfCc
thank you all :-)
Edited on: Tue, Aug 4, 2015 at 5:33:44 AM
It doesn't work because you are using the wrong family. Where did you get that family?
What do you mean by "wrong family"?
i downloaded it here on revitcity downloads.
Edited on: Tue, Aug 4, 2015 at 7:36:42 AM
A lot of families are posted here by users .... We do not test how these families perform so some may not work well. In addition in regards to vegetation families, many of those were built using the original 'accurender' engine that Revit had in it. Those families no loger work with the later Revit editions.
You don't say what family it was that you downloaded so I can't check it out. You will have to open the family and look at it. In addition, if it is a type based family, you have to have the type catalog on your system, not just the family.
Actually i think it's not working with ALL of the tress.
my revit version is 2016.
the tress are all older files (2009 and eraliaer)
i attached some examples for trees with the problem.
None of those trees will render correctly so why use them?
Did you look at the stock trees?
1. I need abstract trees this time. not well-detailed or RPC trees.
2.What are the stock trees?
The answer is just a few clicks away.....
Sorry i didn't understand you this time.
Massing and Site Tab / Site Component / Load Family / Planting / RPC Tree - ???? Like 6 clicks....
Place it and look at it.
Tree |
Fri, Jul 16, 2010 at 4:19:25 AM
rpc tree |
Tue, Mar 31, 2009 at 12:01:03 PM
Changing paramaters of 'Title with line' |
Wed, Sep 20, 2006 at 9:47:18 PM
Elements missing from elevation when behind a transparent tree |
Tue, Jan 27, 2015 at 7:00:25 PM
tree render |
Mon, Oct 13, 2008 at 2:12:37 PM
