31 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Change the material for imported SKP model
Hey again,
Since i didn't find an abstract tree for revit, i downloaded a great tree from 3d warehouse to skechup.
when i import this tree to revit it'll always render on grey. is there any way to change the matrials for imported 3d CAD to SKP models?
Materials for CAD based products like sketchup are controlled by assigning materials to their layers. You can do that through the manage tab/object styles/imported objects.
Thank you.
it work with some elemets while others not.
The sketchup item has to be built correctly with surfaces that would be different on different layers. You may be able to edit the sketchup file to fix this.... but it sometimes takes a lot of work. I find that a lot of these items are done poorly for our needs.
This old post might help.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=29146
Just check if any surfaces in SU was done with paint bucket.
If so, you have to remove them.
Edited on: Tue, Aug 4, 2015 at 9:34:16 AM
Thank you. i'll check it out.
No colour for rendered skp files |
Thu, May 7, 2009 at 10:24:37 AM
SKP to RVT |
Sun, Apr 22, 2012 at 6:42:04 AM
imported file |
Tue, Aug 17, 2010 at 9:28:42 AM
How to change material of an rfa files on the download sections? |
Sun, Jul 12, 2009 at 9:27:06 PM
Family Materials on Imported SKP files: Car colors |
Mon, May 9, 2011 at 7:40:07 PM
Members: | 2066361 | Objects: | 23085 | Forum Posts: | 152255 | Job Listings: | 3 |
