38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Rebar Visibility
Mon, Aug 3, 2015 at 11:32:54 PM | Rebar Visibility
Afandy
hi guys , i have revit 2016 and rebar is shown as a singlr solid line and i want to show it as this pic or double line
Tue, Aug 4, 2015 at 1:48:19 PM | Rebar Visibility
Kheops
hi, Afandy,
- select the rebar
- in your properties browser, cilc to VIEW VISIBILTY STATES
- then, check the box 'VIEW AS SOLID'
best regards,
Saidou
Wed, Aug 5, 2015 at 10:06:36 AM | Rebar Visibility
Afandy
thanks sir but it has a black strock can i hide it ?
Wed, Aug 5, 2015 at 10:49:34 AM | Rebar Visibility
Kheops
YES YOU CAN HIDE IT.
in your 3d view, go the properties browser
- click to GRAPHIC DISPLAY OPTIONS
- AT THE DIALOG BOX, CHECK 'SHOW EDGE', (see attached picture), then the black line will be hidden
Best regards,
Saidou
Sat, Aug 8, 2015 at 11:21:33 AM | Rebar Visibility
Afandy
Thanks sir thank you very much
i have another question please
i sections i want to display the rebar as a Double Line as the pic
how can i sir ?
Tue, Aug 11, 2015 at 9:44:10 AM | Rebar Visibility
Kheops
Hi,
you can make it just by checking your detail line level.
- click to the detail line level button locate at the bottom ( as shown by the attatched picture)-
 then select 'FINE'
Hope thats hepls you
Tue, Aug 11, 2015 at 3:35:53 PM | Rebar Visibility
Afandy
thanks sir
Question about rebar visibility in Shaded view
Mon, Apr 29, 2013 at 2:19:18 PM
How to apply the rebar in a ramp.
Mon, Jul 5, 2010 at 4:53:04 AM
Need help to modify rebar bar size!!!!!
Thu, Apr 6, 2017 at 3:03:05 AM
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
Rebar View Visibility Problem
Tue, Sep 20, 2011 at 1:41:38 PM
Page generation time: 0.3495
