91 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> building environment
![alarife Avatar](user_avatar/644800.jpg)
Dear all,
Once again, I am here asking you to find a solution to my problems!
I need to model the built environment of my project, there are other buildings that should be taken into consideration when presenting the project, but I don't want them to appear in schedules.
What is, in your opinion, the best solution? Modelling them as masses?
Thank you!!
Too many solutions..
- Use imagery
- Google world?
- Masses... maybe
- Model in another linked file (s) << Better than in your main file. They can be masses that you apply images to.
Thank you very much WWHub!
I've tried at last to model the neighboring buildings as masses, and it is working fine. I would try the other options you told me in case that this one will stop working.
Regards
Sharing Coordinates Conceptual Mass Environment and Project Environment |
Sat, Nov 16, 2013 at 10:14:00 AM
Revit and IES Virtual Environment |
Fri, Feb 13, 2009 at 6:25:01 PM
14
2013_reference line in project environment |
Fri, Dec 14, 2012 at 12:40:58 PM
Deleting an element within 3D environment doesn't delete the element from the 2D |
Tue, Jun 26, 2012 at 12:46:07 PM
a better 3D modelling environment |
Mon, Aug 6, 2012 at 1:10:07 AM
Members: | 2022428 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
