15 Users Online (14 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> door tag types
Fri, Jul 31, 2015 at 7:46:06 PM | door tag types
thedraftingstudio
Is it possible to have multiple types of door tags in one file?
Example: 1 using a square tag and 1 using a hexagon
Sat, Aug 1, 2015 at 12:30:14 PM | door tag types
CDWdavid
5 Stars: 5 Votes
Yes, sure you can do it.
Just make a copy of your square tag family and modify it to the hexagon shape and give a different name.
Our office has Door/Window/Gate schedule, with three different tags for the plans and all types shown in one schedule.
BTW, not three tags in one family, but one family for each type of tags.
Edited on: Sat, Aug 1, 2015 at 10:44:53 PM
Thu, Sep 3, 2015 at 6:39:54 PM | door tag types
chilie
If you wanted to have different line symbols all in the same family, you can just control that with yes/no parameters. Just create the shape you want and under the property palet select "visiblity" and assign those lines to that yes/no parameter. Then just set up the family types to turn off and on what lines you want.
Electric Door TaG
Tue, Feb 11, 2014 at 5:28:23 AM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Door and Window types
Thu, Nov 23, 2017 at 11:19:52 AM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Page generation time: 0.5466
